avital 5303l no remote start wanted
lightmind
Posted: June 16, 2013 at 5:21 PM / IP Logged
I have a Avital 5303 to be installed in a '06 Sprinter 3500. After researching the installation I am unclear on a few items.
I do not plan on using the remote start, only the alarm will be wired. I do have 556uw bypass module.
Here are my questions...
If I am not using the remote start function, do I need the wire the bypass module?
Will the alarm system integrate with the system immobilizer in the Sprinter without the bypass- can I arm / disarm on either the Avital or the factory keyfob remote?
Will the doorlocks work using either the Avital or factory remote?
Thanks.
Posted: June 16, 2013 at 6:21 PM / IP Logged
You won't need either the 556U or the factory remote to lock the doors.
You will need a 451L and a second relay, here's why.
Under the right hand seat on UK spec., i.e. driver's side are a cluster of relays.
You need motor wire access hence the 451l to lock and unlock the front doors.
A second relay then unlocks the side and back doors.
Posted: June 16, 2013 at 6:35 PM / IP Logged
US version, AKA Dodge Sprinter is slightly different, above refers to LEFT HAND seat.
Lock all 5 wire blue/red, CTM* pink plug pin 2.
Unlock driver's door, BLACK/ red diito pin 3.
Unlock passenger and cargo doors , BLACK/ red CTM* grey, pin 17.
Door triggers from memory, pull the dome light in the front, BROWN / white (-), front, there's an adjacent loom above that light, has another BROWN / white, test but this should be the side/rear door triggers.
Ignition, lights, etc drop steering wheel cowling or pop instrument binnacle, you can also get the alarm brain and the antenna in there.
About the easiest vehicle going!
*CTM = central timer module.
lightmind
Posted: June 16, 2013 at 7:41 PM / IP Logged
Ok, I don't know what the 451l is but I think this is the same?
http://www.remotestartexperts.com/dei-451m-doorlock-relay-module.html
Also, will I still be able to use the factory keyfob for lock / unlock (WAF)?
Thank you all!
Posted: June 17, 2013 at 12:44 AM / IP Logged
Yes but the factory fob won't control the 5301.
lightmind
Posted: June 17, 2013 at 9:12 AM / IP Logged
How about the 5303?
Posted: June 17, 2013 at 9:30 AM / IP Logged
Sorry, I meant 5303.
lucasoil4u
Copper - Posts: 317
Posted: June 17, 2013 at 3:39 PM / IP Logged
No bypass is needed. You will probably have to hook up ignition wire on the heavy gauge harness for programming and such. Any other questions?
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
