2012 dodge ram 3500 door lock issue
robd007
Member - Posts: 25
Posted: June 21, 2013 at 12:15 PM / IP Logged
I have a Ram that I installed an APS 25C in about a year ago.  The issue I am having is that if the alarm is set before the doors are all closed, the locks will not unlock.  They will  not unlock with the alarm remote or the door lock switch.  If all doors are closed and the alarm is set the locks work fine.  I tried disconnecting the dome supervision wire but had the same result.  Has anyone had this issue, or have any idea what may cause this.  Thanks for any info.
Platinum - Posts: 13,726
Posted: June 21, 2013 at 5:50 PM / IP Logged
Where and what color wires did you catch for Door lock? Did you use resistors? If so, what values?
Posted: June 21, 2013 at 11:30 PM / IP Logged
Why would you set the alarm BEFORE you shut the door?
robd007
Member - Posts: 25
Posted: June 22, 2013 at 11:56 AM / IP Logged
I used the purple and light green with a 330 ohm resistor on the lock and 100 ohm on the unlock and as far as setting the alarm before the doors were closed the customer accidentally did it. He knows now to be careful about it but it seems strange that no lock or unlock functions would work even using the door switch.
lucasoil4u
Copper - Posts: 317
Posted: July 02, 2013 at 2:21 PM / IP Logged
did you use relays and diodes?
robd007
Member - Posts: 25
Posted: July 02, 2013 at 3:27 PM / IP Logged
I did use relays but no diodes that could be my issue where would I place the diodes.
pts760
Copper - Posts: 403
Posted: July 04, 2013 at 7:21 PM / IP Logged
place the diodes inline with the unlock/lock wires coming from your relays to the purple light green vehicle unlock/lock wire. Here's a diagram:
2012 dodge ram 3500 door lock issue - Last Post -- posted image.
I drink current, eat ohms, and bleed voltage
robd007
Member - Posts: 25
Posted: July 04, 2013 at 7:28 PM / IP Logged
Thanks for the help I will install the diodes. Thanks for the illustration.
