wiring amplifier, woofers, capacitor?
outlawx16x
Member - Posts: 6
Posted: July 09, 2013 at 6:51 AM / IP Logged
4000watt boss mono block class D amp 1-8 ohm,
12 kicker solo barak 2 ohm wired in factory box,
2 12' mtx thunder 5500 2 ohm wired in factory box,
.5 uf farad scorch capacitor
4 gauge scorch wire kit,
how do I wire it up together? at a 1 ohm load. for the full 4000w x1
any help would be appreciated: Thank You in advance..
-vipofthc
DYohn
Platinum - Posts: 10,741
Posted: July 09, 2013 at 7:17 PM / IP Logged
4-gauge wire will support up to around 1000 watts. What size fuse is included in your wiring kit? What is the make/model of the amp?
outlawx16x
Member - Posts: 6
Posted: July 10, 2013 at 3:13 AM / IP Logged
Currently running in my 98 ford expedition.
to answer the question its a 4gauge /60 amp fuse and amp is AR4000D.
http://www.walmart.com/ip/Pyle-PLAM40-4-Gauge-Amplifier-Installation-Kit/21607394?findingMethod=rr
http://blogs.rediff.com/alliztafipo/2013/05/12/scosche-capacitor-walmart/
http://archive.mtx.com/caraudio/products/subwoofers/thunder5500.cfm
http://www.bossaudio.com/auto/class-d-monoblock-vehicle-power-amplifier-remote-subwoofer-level-control-ar4000d/
https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41
would like to add the kicker in the thing too...
outlawx16x
Member - Posts: 6
Posted: July 10, 2013 at 3:25 AM / IP Logged
kicker listed below
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/4554011/vpcsid/0/SFV/30046
DYohn
Posted: July 10, 2013 at 10:17 AM / IP Logged
OK. As long as you understand that amp is 1500 watts at best and with a 60-amp fuse in your power cable the max your wiring will support is approximately 860 watts. IMO you can sell the capacitor on Flea-Bay or use it as a paperweight as it's not going to do you any good.
Assuming your woofers are both 2-ohms connect them in parallel to the amp since it claims to be 1-ohm stable. Then set the gain properly (see the Hot Topics forum if you need a how-to.) Consider upgrading the Big 3.
outlawx16x
Member - Posts: 6
Posted: July 10, 2013 at 2:49 PM / IP Logged
thank you but im going to need more info than that to accomplish this properly so i'll just keep checking the post to see if anyone can help with the information I simplified above.
DYohn
Posted: July 10, 2013 at 5:30 PM / IP Logged
What information do you need?
outlawx16x
Member - Posts: 6
Posted: July 10, 2013 at 8:11 PM / IP Logged
to be able to see how this would all be connected to reach one ohm ? ive used the websites calculator to see if 2ohm and a pair of 4ohm wired to 2 ohm - makes 1 ohm stable, but how to wire it, the site doesn't show a photo of a 2 ohm box and a 2 ohm box wired together to achieve 1 ohm.
soundnsecurity
Gold - Posts: 2,720
Posted: July 10, 2013 at 9:19 PM / IP Logged
if each box rests at 2 ohms then you would treat each box like a single coil speaker. but the short answer is just wire every positive together and every negative together. this should give you the 1 ohm load you so very much desire.
DYohn
Posted: July 12, 2013 at 9:56 AM / IP Logged
A "2 ohm box" and a "2 ohm box" wired in parallel creates one ohm. It doesn't matter what's in the box.
