timer relay assistance
greeney64
Posted: August 10, 2013 at 3:15 PM / IP Logged
Hello all.
I have 2 questions really, the first is based on a relay diagram you already have on the site.
I have the vacuum operated locks on my 126 S-Class Mercedes and want to add an internal switch to lock and unlock from inside, there is a diagram in general for this but as a novice I do not know how to incorporate a timer as mine needs 3 seconds I believe could someone assist with this please.
My second question is potentially more exciting in as much as I have been asked by a film co to construct a revolving number plate similar to that of the James Bond AM DB5. The plate will be triangular as it will have 3 alternate plates rolling on a centre pivot
What I would like to do is press a button in the cab and have the plate turn its 110degrees to the next and stop.
My way of thinking was a dual relay system with micro switch running on a cam to a stop position but able to do this continually without having to reset anything.
So one press of the switch rolls the plate to the next.
I thank you in advance for your assistance
pts760
Copper - Posts: 403
Posted: August 12, 2013 at 10:27 PM / IP Logged
What type of switch(s) are you looking for in the Mercedes? A momentary switch for lock and a momentary switch for unlock (two separate switches) or one momentary switch that locks and unlocks the door? How many switches?
I drink current, eat ohms, and bleed voltage
greeney
Posted: August 20, 2013 at 3:20 PM / IP Logged
hello pts760
I would like to operate it from one switch if possible Thank you
pts760
Copper - Posts: 403
Posted: August 25, 2013 at 9:00 PM / IP Logged
Sorry it took me so long, I've been busy at work.
This is what you are going to need:
-(2) 30/40A SPDT Relays
-(1) On-Off-On Mometary Rocker Switch
-(2) DEI 528T Timers...(Here's a link for the DEI 528T)
-fuses, solder, electric tapes, shrink wrap, etc., etc.
timer relay assistance - Last Post -- posted image.
greeney64
Posted: September 03, 2013 at 11:23 PM / IP Logged
Thats fantastic thank you very much
Wednesday, November 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
