adding amp to 06 gmc envoy xl denali
stretch34
Posted: September 20, 2013 at 7:46 AM / IP Logged
I want to add an amp to my 06 GMC Envoy XL Denali with factory navigation. I have been searching for a wiring diagram so I can tap into the rear speakers behind the navigation head unit for the low level input on the amp but have unsuccessful.   Also what wire would I connect to for the remote wire to turn the amp on/off?
Platinum - Posts: 13,723
Posted: September 21, 2013 at 5:10 AM / IP Logged
You will need to find the factory subwoofer and use the wires that lead to it. Try looking in the console.
stretch34
Posted: September 21, 2013 at 5:21 AM / IP Logged
Didnt come with a factory subwoofer
Posted: September 21, 2013 at 8:00 PM / IP Logged
When you removed the radio, did you see the typical Yellow, Brown left rear speaker wires? And the Dark Blue Light Blue right rear wires?
You will have to find a fuse in the fuse box that has power only when the key is in the run position. Usually the Windshield Wiper fuse.
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
