splitting rcs with relays
hondaguy48891
Member - Posts: 11
Posted: November 09, 2013 at 1:45 PM / IP Logged
Hello all,
I have been trying to figure out a way to transfer signal from RCA jacks to go through a line drive then to the amp whena switch is flipped and if I don't want to use the line driver I can shut it off and listen to the sound system normally. Any information or diagrams will be helpful. Thanks in advance
Platinum - Posts: 13,724
Posted: November 09, 2013 at 8:37 PM / IP Logged
One relay per channel.
30 to the input of your amplifier. 87A from your deck. 87 from the line driver. Whenever you energize the relay by placing 12 volts across 85 and 86, the signal from the line driver will get to the amplifier. With no voltage across 85 and 86, signal from the deck will get to the amplifier.
hondaguy48891
Member - Posts: 11
Posted: November 10, 2013 at 7:49 AM / IP Logged
Won't I need 2 relays per channel since there is a a signal and a ground per channel? And should I have to worry about any signal interference?
the12volt
Administrator - Posts: 3,957
Posted: November 10, 2013 at 10:26 AM / IP Logged
The RCA grounds are common. Leave them connected. No need to switch them.
splitting rcs with relays - Last Post -- posted image. the12volt • Support the12volt.com
hondaguy48891
Member - Posts: 11
Posted: November 10, 2013 at 1:05 PM / IP Logged
Thank you
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
