led daytime running lights car
buckarrow
Posted: November 27, 2013 at 2:18 PM / IP Logged
I currently have a 2012 Kia Optima SX. It did not come with LED Daytime running lights. However, I have purchased and OEM model that is used in later car models. My car is not plug and play.
The LEDs that I have are able to run at 50% or 100%.
My plan is to wire them in so that when the ignition is on and headlights are off the DRLs with run at 100%. I would like the DRLs to switch to 50% when the Low beams come on. I would also like to add a switch inside the car (simple SPST) to be able to control them on/off when desired.
I have done a ton of research, including here over the last few days and have come to the conclusion that I need to use a SPDT relay to control the functions I need. The problem is that I don't have the training to put the wires in the correct location once I have the relay. I have found a few posts that have described what I should do but then I see others that contradict that.
What I think I need to do but would love it if someone could confirm or even throw me a diagram? Also, are their stores where I should and shouldn't buy these off the shelf (Pep boys vs. West Marine)?
30 goes to one side of switch and other post of switch goes to fused power source
85 goes to positive side of headlights
86 goes to ground
87a goes to high power or 100%
87 goes to low power or 50%
Thank you for the help
Mike
powerslave
Copper - Posts: 126
Posted: December 07, 2013 at 7:46 PM / IP Logged
Didn't you post this already, and wasn't it answered? I distinctly remember it. I think it was in a different section, thus THIS is a double post. Well, one of them are. Seems moderation is a little lax.
oldspark
Gold - Posts: 4,913
Posted: December 08, 2013 at 1:01 AM / IP Logged
This is a duplicate (OP posted the same day) of new led drl for 2012 kia optima.
And yes, it was answered.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
