viper 5704 in 1985 mustang gt
stanced stang
Posted: December 11, 2013 at 8:34 PM / IP Logged
I just stumbled upon this wealth of information, and thought it would only be appropriate to see if I could get some answers to simplify my install. I have a 1985 Mustang GT, which is the last year of the carburetor. With that being said, remote start will be almost useless unless the car is fully warmed up. I do plan on eventually doing a stand-alone E.F.I. setup, so I would like the remote start to be wired in. I do not see much in the way of information on my car, probably being it is as old as it is. Would there be any tips or tricks I should be aware of seeing as this is my first security system/remote start install? Thank you in advance, Chris.
The Car;
viper 5704 in 1985 mustang gt - Last Post -- posted image.
Platinum - Posts: 7,827
Posted: December 11, 2013 at 9:48 PM / IP Logged
Nice GT.  I had an '86 that was a lot of tail-happy fun even with an 85 MPH speedometer!
Looks like you can get some wiring info from these sites :
Here is a link to Ready Remote :  http://www.readyremote.com/main.asp
Here is a link to AudioVox :  http://techservices.audiovox.com/AccessRequest.aspx    Sign-up & info is free.
It is possible to do a remote start in a carb'ed vehicle.  You could use an AUX output to trigger a relay that
controlled a solenoid that would be installed in such a way to hit the carb's throttle butterfly and prime it and
set the choke ( to simulate depressing the gas pedal prior to a cold engine remote start )...
Tuesday, November 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
