autostart antenna
edweather
Posted: January 04, 2014 at 12:08 AM / IP Logged
Long story short....had an Autostart remote starter professionally installed 5 years ago. I use the maximum start range of about 1200'. After a couple of years the range decreased significantly, so under warranty they replaced the antenna. It worked like new again. Now 2 years later, same thing. They didn't want to give me another antenna, so I just purchased one and they said it was plug-n-play, but should probably replace the harness (comes with it) also. Tonight I was short on time, but the temp was -5F, so I just unplugged the old antenna and plugged new one in just to see if it works. NUTHIN'...didn't respond at all. So I plugged the old one back in and it works. What am I doing wrong? Model # of new antenna is the same. I will check my original installation instructions when I get home, but just thought I'd put this out there for any suggestions. Thanks. Ed
prdjr165
Copper - Posts: 293
Posted: January 04, 2014 at 9:28 AM / IP Logged
you probably have to program the remotes to the new antenna...
edweather
Posted: January 05, 2014 at 8:14 AM / IP Logged
They didn't say anything about programming, and I asked them several times.  The only thing they suggested was that I make sure to relpace the harness too.  I have the original installation instructions and it says nothing about programming the remotes to the antenna.  I'll give it another try, and if I can't get it to work, I'll just let them do it and pay the upcharge.  Thanks.  Ed
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
