09 pontiac g6
ziggyb222
Silver - Posts: 593
Posted: January 13, 2014 at 7:48 AM / IP Logged
Can the 09 Pontiac G6 immobilizer be bypassed with a key in the box and do the one wire locks with the 1.5k resistor???
ziggyb222
Silver - Posts: 593
Posted: January 13, 2014 at 6:34 PM / IP Logged
Any help would be great!!!!!
Platinum - Posts: 7,827
Posted: January 13, 2014 at 8:01 PM / IP Logged
Think it's new generation Passlock2.  Relays and resistor will work.  Does the ignition key have a "+" sign inside of a circle?  I believe they are the same as the Malibu.  I usually use the iDatalink ADS DL with GM2 firmware.  It takes care of everything.
Yes, one-wire door lock system.  Lock is a straight ground and Unlock is ground through a 1,500 ohm resistor.
Saturday, September 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
