relay deactivates switch when power
tahoe45
Member - Posts: 20
Posted: January 30, 2014 at 8:53 AM / IP Logged
Hey everyone,
is there a relay that exists that when there is power supplied to it. The Switch that is connected to it is inactive and then when you cut the power to the relay it is active? For an example I would like to wire up a switch to the negative wire of the door popper so the switch would complete the ground when pushed. I was thinking of running the acc power from my car to the relay. So in the end when the car is off the switch is active and when the key is in the ignition and turned to on the switch is inactive. Sorry if this is a confusing post, but any suggestions or help would be greatly appreciated.
oldspark
Gold - Posts: 4,913
Posted: January 30, 2014 at 10:16 AM / IP Logged
SPDT relay.
IGN +12V to 86
GND 85
30 & 87a for the switch.
87a & 30 are NC = Normally Closed contacts with coil 86/85 de-energised.
With IGN on 30 & 87a open thereby disabling the switch.
tahoe45
Member - Posts: 20
Posted: January 30, 2014 at 10:26 AM / IP Logged
Awesome. So will 30 and 87A be negative or positive?
oldspark
Gold - Posts: 4,913
Posted: January 30, 2014 at 4:49 PM / IP Logged
It doesn't matter. 30 & 87A are merely 'inserted' into whatever you want switched. In your case this is from your switch.
Because relay coils and contacts are independent (except for specialised types like 3-pin horn relays) it doesn't matter what voltage or polarity the contacts have.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
