viper 5704 will not go into programming
ttzhang
Member - Posts: 12
Posted: February 25, 2014 at 7:59 PM / IP Logged
Did you figure out the issue?
Having the same issue. No LED flashes / chirps to select different menu... was working fine then stopped working.
Thanks!
freqsounds
Copper - Posts: 289
Posted: February 25, 2014 at 10:12 PM / IP Logged
Stupid question, but are you sure it's not stuck in valet mode? Have you tried a power cycle on the Viper unit (like pull the fuses, wait a minute, put them back in)?
No question is stupid or not worth asking. You were once a noob, right? :)
itsyuk
Silver - Posts: 505
Posted: February 25, 2014 at 10:50 PM / IP Logged
pulling fuses wont take it from valet mode..... or even armed mode.
what ever mode it was in when disconnected is what it will be in when it gets reconnected.
the oldest dei alarms like the original 300 would default to be in full alarm mode when first connected to power but for the last 15+ years dont do that.
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
freqsounds
Copper - Posts: 289
Posted: February 25, 2014 at 11:13 PM / IP Logged
I know, I meant them as two separate questions lol, sorry! I have a bad tendency to group my questions.
ttzhang
Member - Posts: 12
Posted: February 26, 2014 at 10:09 PM / IP Logged
Thanks for reply.
If it's in the valet mode, the blue LED on the control center should be on, right?
Maybe I should try the power cycle.
freqsounds
Copper - Posts: 289
Posted: February 27, 2014 at 8:09 AM / IP Logged
DEI wrote:
Press (f) two times, and then (unlock) to put the alarm into/out of Valet Mode. The disarm LED flashes and the remote beeps once indicating entry into Valet mode. Repeating the process takes the alarm out of Valet Mode. The disarm LED flashes and the remote beeps twice.
The security system’s LED will come on solid when in Valet Mode and will shut off when exiting Valet Mode.
When locking the system in Valet Mode, the Lock and Function LEDs light for one second and emit an error tone. When unlocking in Valet Mode, the Lock and Function LEDs light for one second and emit 2 error tones.
freqsounds
Copper - Posts: 289
Posted: February 27, 2014 at 8:13 AM / IP Logged
Give that a shot. If I remember correctly, the screen will tell you if you're in valet mode or not.
The other thing is, the system detects the key's ON position through the Ignition1 input/output wire. It may be worth checking this as well. Double check to make sure your door triggers work. Those are the two things needed to get into programming mode.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
