understanding diagram
astra_rob
Posted: March 15, 2014 at 11:59 AM / IP Logged
Im trying to get my head around a diagram on the the site but im curious about one thing. I want to add this to an alarm system, but i cant work out what the circular icon is, with the ORANGE / brown x/l. Hope someone can help, many thanks.
https://www.the12volt.com/relays/page4.asp#lf3
howie (aka: harryharris)
Silver - Posts: 355
Posted: March 15, 2014 at 12:07 PM / IP Logged
It's a flasher relay feeding a light unit, e.g. indicator or headlight.
All decent alarms sold have one or two light outputs already.
DEI, Clifford/Viper etc. One white split via diodes for the indicators.
Cobra as sold in Europe 2 x yellow. Etc.
Test before boxing up.
astra_rob
Posted: March 15, 2014 at 1:34 PM / IP Logged
Thank you harry, you've made me realize ive been having a blonde moment. I already have built in relays feeding flashing indicators. Depending on the ampage output of these internal relays, is it possible to connect these to the main beam circuits also or am i likely to need to add a spdt relay? Thanks for your help
Silver - Posts: 355
Posted: March 15, 2014 at 2:35 PM / IP Logged
Yes definitely but not necessary for a SPDT that's 5 pins, you only need a 4 pin SPST relay or don't use 87a on the type you mentioned.
If headlights you'll need a 15 amp fuse as well to supply the relay(s)*
*Some cars have twin isolated high and low beam circuits.
From what I know about the Astra, after 2005 you'll have to pick up the headlights around the front fuse box area, it's all CAN data inside the car.
Silver - Posts: 355
Posted: March 15, 2014 at 4:31 PM / IP Logged
Just thought of something, after you join to the alarm indicator wire(s) you need to insert a diode 1N5404 between the relay join and where you join to the indicators, band side towards the indicators.
Otherwise using the indicators whilst driving will bring on the headlights.
oldspark
Gold - Posts: 4,913
Posted: March 15, 2014 at 10:54 PM / IP Logged
Keep in mind that that circuit requires a headlight - or at least 2 x 21W bulbs or 50W resistor etc - for the flasher can to work UNLESS hyperflashing is acceptable OR a non-load sensitive flasher as used for LEDs etc (except in OEM vehicles) is used.
IMO for flashing other loads or low power things it's much better to use an electronic circuit - eg, 555 timer or any of several simple designs; sometimes available in kit or module form (maybe some DEI relay?).
Silver - Posts: 355
Posted: March 16, 2014 at 2:09 AM / IP Logged
It's an old diagram, any way it just occurred to me that if you were using an ON/OFF flasher circuit you wouldn't need it anyway.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
