turn off headunit with alarm
Posted: May 05, 2014 at 1:32 AM / IP Logged
No trick, just separate your Sony red and yellow as explained above yours ONCE AGAIN isn't wired correctly.
Ref. window and roof close. If it's possible extend your lock wire from the alarm to about 15 seconds that will give you window and roof (if factory)close.
the12volt
Administrator - Posts: 3,959
Posted: May 05, 2014 at 8:54 AM / IP Logged
You could use the unlock output from your alarm to supply power to your head unit's red wire and the lock output from your alarm to kill power using the following relay setup.
turn off headunit with alarm - Page 2 - Last Post -- posted image.
turn off headunit with alarm - Page 2 - Last Post -- posted image. the12volt • Support the12volt.com
Platinum - Posts: 13,725
Posted: May 05, 2014 at 11:30 AM / IP Logged
He will have to pulse that setup with (-) to turn it on.
Maybe the Retained Accessory relay setup can be used instead.
mr signal
Member - Posts: 34
Posted: May 05, 2014 at 1:33 PM / IP Logged
Hi.I connected it like you have it in pic with the 3relays.the headunit only lights when disarming for one second and dies again,1st and 2nd relay clicks when disarming.it doesn't stay on inorder to shut off when you arm.relay 3 doesn't click at all.I changed relays but still no luck.lock/green wire is connected as turn of and.blue/unlock is connected as turn on
Mr signal
mr signal
Member - Posts: 34
Posted: May 05, 2014 at 2:38 PM / IP Logged
Appologies guys,I got it right it was a wire problem.thanks to the guy with the diagram it worked perfectly.thumbs up to this site wow
Mr signal
Posted: May 05, 2014 at 4:57 PM / IP Logged
I guess it helps if I do not just look at the pictures.
Posted: May 05, 2014 at 4:59 PM / IP Logged
Or none of the above Craig if the radio was wired correctly in the first place.
