Finding tachometer
sador
Copper - Posts: 57
Posted: June 17, 2002 at 11:01 AM / IP Logged
 Hi Everybody!!
Can you help me to find the tachometer  using a digital multimeter? Honda Civic 20001.
                                                 Thank You
Platinum - Posts: 12,488
Posted: June 17, 2002 at 11:19 AM / IP Logged
There is a 2 pin plug on the passenger side of the car by the battery and there you will find a BLUE wire to tap into. This wire will test with a DMM set to AC , put the red lead to 12 volts and the black lead to the target wire. The DMM should register 1 volt > in AC and will rise as the accelerator is pressed.
