Posted: June 04, 2014 at 4:00 PM / IP Logged
Posted: June 05, 2014 at 2:12 PM / IP Logged
Posted: June 05, 2014 at 3:28 PM / IP Logged
Posted: June 05, 2014 at 3:35 PM / IP Logged
Posted: June 05, 2014 at 3:46 PM / IP Logged
Posted: June 05, 2014 at 4:05 PM / IP Logged
Posted: June 05, 2014 at 10:32 PM / IP Logged
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I would like to put a bunch of outlets in our 15p van which we use for LONG road trips. I'm thinking 5-6 outlets. I expect we'll need about 20 amps total. I have one non-switched spare slot in my fuse box.
I was going to use an "add a fuse" tap thing to avoid messing around in my fuse box. It says max 20 amps, but that 16 gauge wire coming out of it seems on the small side. Am I really okay to use one of these on a 20a circuit?
If I was to bump it up to 30 amps total, I should run 2 separate circuits, right? This one from China that says 30A looks exactly like the 10A one at Napa so I'm skeptical: http://www.ebay.ca/itm/5A-10A-15A-20A-25A-30A-Mini-Blade-Fuse-Tap-Holder-Add-A-Circuit-Line-ATM-APM-Car-/151042020866?pt=US_Car_Audio_Video_Fuses_Fuse_Holders&hash=item232ace5602&_uhb=1
What gauge wire should I use? The back of the van is about 15' from the fuse box.
What's the best way to branch off the outlets from the power source wire? T-taps?
Any suggestions for the best place to ground? The outlets are going to be mounted next to the cupholders at the window ledge.
Does 20 amps sound reasonable for a few LCD screens and some ipods charging? Or should I go for 30 amps? Or more? :p
Thanks!!!
You would use a standard bosch 30/40a relay available at most auto parts stores.
Pin 86 would go to the brown accessory wire in the photo.
Pin 85 would go to a good ground.
Pin 30 would go to 12v constant from the fuse box or battery. (fuse for the entire circuit will be within 18 inches of the battery source)
pin 87 will be the supply for the new accessory sockets.
This will give you switched power on all the sockets. It MAY (not completely sure) give you RAP (Retained Accessory Power) on that circuit as well. Added bonus.
