autowatch car alarm remote programing
mr signal
Member - Posts: 34
Posted: June 09, 2014 at 4:41 AM / IP Logged
How do I program a new remote to a 276 autowatch alarm.? i have programed a new remote to a autowatch 446 before and it was quite easy with the ignition .when you switch the ignition on while the immobiliser is active the movement sensor light will stay on. But it doesn’t do the same with the 276 autowacth. when you switch the ignition on while the immobiliser is active the light keep flashing, can anyone tell me how to program a new remote to this module.
Mr signal
Posted: June 09, 2014 at 8:54 AM / IP Logged
Again it's a product made in South Africa, as I've already told you contact Conlog.
The only person on this site who's even heard of them is me.
mr signal
Member - Posts: 34
Posted: June 09, 2014 at 9:09 AM / IP Logged
Appologies thank you.
Mr signal
subaruimpreza
Posted: November 04, 2014 at 5:14 AM / IP Logged
Hi There,
Autowatch is a product from South Africa, is manufactured by PFK Electronics and you can get them here: http://autowatch.pfk.co.za/contact_us/head_office.htm The product in question cannot be programmed the same way as with the 446RLi. You will need the 5 Digit code on a sticker inside the box, send it to PFK and then - with a new solder-able remote - solder in the new code.
Fitment Centre
