Relay to end 12v sources.
adamd
Posted: May 19, 2003 at 10:15 AM / IP Logged
Guys need help on wiring a relay to kill my starter, fuel pump.I dont want an alarm just keep my car parked. The only help I ca find is with a (-) output of the alarm.
All I want is to cut any 12v wire source to move any to any component like the ignition, fuel pump or starter.
Any suggestions.
auex
Platinum - Posts: 5,041
Posted: May 19, 2003 at 4:59 PM / IP Logged
If you already have diagrams then all that you would need is a toggle switch to act as the, as you put it," (-) output of the alarm". Just wire one ends of the switch to ground and the other to the relay. Just substitute the toggle switch for the "ground when armed". Here is a link to some diagrams Starter Kill Systems
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
