opel corsa 2005 lock and unlock wires
mr signal
Member - Posts: 34
Posted: August 01, 2014 at 2:39 PM / IP Logged
Hi what colours are the lock and unlock wires on a opel corsa 2005 model.it has keyless entry on the facory key but its nolonger working,so I'm going to install an alarm that has neg and pos central ocking signal outputs.your feedback will be highly appreciated thanks
Mr signal
Posted: August 01, 2014 at 5:12 PM / IP Logged
European Corsas of that era had data driven lock systems controlled by a CAN alarm or add on CAN module.
If earlier shape, loom behind glovebox, left hand side, RED / yellow lock, RED / blue x 2 unlock
mr signal
Member - Posts: 34
Posted: August 01, 2014 at 10:08 PM / IP Logged
Thanks a lot Howie.I will check if I can see those wires,if not I will know to purchase a can module.just for my own interest howie.in the future,how will I know which vehicles needs Canbus modules and which vehicle does not need it.and the vehicles that needs canbus modules,will there be no neg or pos signals that operate the locks? just trieng to figure out how it works.thanks in advance.
Mr signal
Posted: August 02, 2014 at 12:52 AM / IP Logged
Solely depends on the vehicle, also as you pointed out, the S/African models can run up to two years behind on the electrics.
