1993 camry ignition harness location?
Zich
Member - Posts: 8
Posted: May 20, 2003 at 8:02 AM / IP Logged
Does anyone know where the ignition harness on a 93 camry is? The wiring information gives colors, but not locations.
cpgoose
Gold - Posts: 1,098
Posted: May 20, 2003 at 8:13 AM / IP Logged
You should be able to take off the panel above the driver's knee (just below the steering wheel), and you should be able to see a bunch of wires coming down the steering column and across. Basically right behind the panel you just removed.
camry0099
Member - Posts: 41
Posted: May 21, 2003 at 9:46 AM / IP Logged
cpgoose is right, there are four 10mm bolts that hold the panel on. Once you get that off, there is a air duct that needs to be removed for easier access to the harness.
Zich
Member - Posts: 8
Posted: May 21, 2003 at 9:52 AM / IP Logged
Thanks guys, I figured it out and got everything installed yesterday :) Didn't have to remove the air duct though!
