2005 dodge caravan
36isherwood
Posted: October 26, 2014 at 2:26 PM / IP Logged
I am installing a compustar 1way with a blade al on a 2005 dodge caravan I have never installed a remote starter in a dodge before and was wondering if I need to worry about the 2 starter wires or if the blade will accommodate all starting features
Platinum - Posts: 7,828
Posted: October 26, 2014 at 2:56 PM / IP Logged
The Blade AL flashed with DL CH6 firmware will control the Starter2 MUX through data, no need to connect anything to the
Starter2 PURPLE / Brown wire. However, you still must connect the Compustar thick ignition output wires to the Caravan's
ignition wires at the main ignition switch harness ( Yellow = Starter and Pink/White = Ignition ). There is no Accessory
wire on this vehicle.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
