03 ram 1500 viper 5706v
jimfren
Posted: November 09, 2014 at 3:12 PM / IP Logged
need help with my install
03 dodge ram 1500 quad cab
installing a viper 5706v security/remote start
been searching for 4 days now. i have the quick reference install guide for the alarm. ive printed the wiring info from bulldog security and from this site. i just need help with a couple wires:
h1/6, h2/1, h2/17, h2/21, h2/23, h3/3, h3/4 h3/9, h310
and if someone could double check me i would appreciate it
h1 6 pin connector
h1/1 red +12v constent imput======pink/black or RED / white ignition harness
h1/2 black -chassis ground=====ground
h1/3 brown + siren output====siren
h1/4 WHITE/ brown parking light isolation wire==pin 87a BLACK / YELLOW of relay under hood
h1/5 white parking light output===purple / YELLOW headlight switch through a 330ohm resister and new relay
h1/6 orange -500ma ground when armed output==not used?
h2 24 pin connector
h2/1 pink/white - ignition 2/flex output== ?
h2/2 blue/white - 2nd status/rear defrost==not used
h2/3 RED / white - trunk release===not used
h2/4 BLACK / YELLOW - dome light==brown drivers a pillar cluster
h2/5 dark blue - status output==not used
h2/6 WHITE/ black - aux 3 output==not used
h2/7 WHITE/ violet - aux 1 output==not used
h2/8 ORANGE / black - aux 4 output==not used
h2/9 gray - hood pin input==hood pin
h2/10 blue - trunk pin instant trigger input==not used
h2/11 WHITE/ blue activation input==not used
h2/12 violet/white tach input==coil pack
h2/13 BLACK/ white - neutral saftey==ground out
h2/14 GREEN/ black - factory alarm disarm output===not used
h2/15 green - door input===all 4 door triggers
h2/16 BROWN / black - horn honk output===BLACK/ red steering column
h2/17 pink - ignition 1 output=== ?
h2/18 violet + door input===not used
h2/19 violet/black - aux 2 output===not used
h2/20 brown + brake shutdown input
h2/21 violet / YELLOW - starter output== ?
h2/22 gray/black - diesel wait to start input==not used
h2/23 orange - accessory output== ?
h2/24 GREEN / WHITE - factory alarm arm output== not used
h3 10 pin connector
h3/1 no connection
h3/2 RED / black +12v accessory/stark input==pink/black or RED / white ignition harness
h3/3 pink/black + flex relay input 87a key side (if required) of flex relay=== ?
h3/4 pink/white + ignition 2/flex relay output=== ?
h3/5 red +12v ignition 1 input===pink/black or RED / white ignition harness
h3/6 green + starter input key side===yellow ignition cluster
h3/7 violet + starter output engine side===yellow ignition cluster
h3/8 orange + accessory output===green and orange ignition cluster
h3/9 RED / white + 12v ignition 2/flex relay input 87=== ?
h3/10 pink + ignition 1 input/output=== blue? ignition harness
smokeman1
Platinum - Posts: 1,589
Posted: November 09, 2014 at 4:06 PM / IP Logged
H3/9, H3/2, H3/5 to 12v source
H3/10 to Ignition 1 (16ga) wire
H3/4 to Ignition 2 (16ga wire)
H3/8 to Accessory 1
H2/23 to pin 85 of relay, Pin 30 to Accessory 2, Pin 86 & 87 to 12v source...need to separate the ACC Green and Orange
H1/6, H2/1, H2/17, 7 H3/3 not needed.
H1/4 disconnect it
jimfren
Posted: November 09, 2014 at 4:14 PM / IP Logged
Thanks for the help I'm gonna install this week
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
