viper 5706v into '03 tahoe,1st timer
turbotalon1g
Posted: December 09, 2014 at 7:30 PM / IP Logged
Virgin Installer, Viper 5706v/Dball2 into a '03 Tahoe Z71.
I've done a lot of work on cars and I enjoying wiring, however I have never installed a remote start/alarm system.
Any tips? I've read Krog's install and will be using that as a guide.
Aaron
turbotalon1g
Posted: December 13, 2014 at 1:08 PM / IP Logged
I'm stuck guys, do I tie ignition 1 and ignition 1 fused together then tap into the car?
smokeman1
Platinum - Posts: 1,589
Posted: December 13, 2014 at 3:28 PM / IP Logged
The Red, RED / White, and RED / Black, (all wires with the fuses) go to a constant 12 volt source.
The Pink wire goes to the vehicles Ignition 1 wire
Follow Kreg's install pictorial, with the help of your DMM.
turbotalon1g
Posted: December 14, 2014 at 10:46 AM / IP Logged
Got it figured out, raises a lot of questions though, getting the dball2 setup in a few hours
turbotalon1g
Posted: December 14, 2014 at 9:22 PM / IP Logged
Got the dball2 programmed, but I'm unable to get the control center button to access the menu I need.
Does the neutral safety switch, I'm taking the physical chrome switch that says on/off have to be grounded?
tedmond
Gold - Posts: 4,610
Posted: December 14, 2014 at 10:44 PM / IP Logged
the neutral safety needs to be grounded for remote start. For programming it needs to see ignition and door pins
Ted
Compustar Expert
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
