diode isolating
specs
Copper - Posts: 120
Posted: January 07, 2015 at 9:10 AM / IP Logged
First install using diodes to isolate some of the connections to vehicle this weekend.....2014 Mazda 3 hatch manual trans/ AL-CA flashed with AL-DL MA3/Klon(W2W). My question is concerning placement of the diodes...does it matter where in the wiring they are i.e. closer to vehicle connections or R/S? Also, have a mix of 4001 and 4007 diodes to use...both serve the same purpose as far as isolating, correct? Thx, Al
Posted: January 07, 2015 at 12:10 PM / IP Logged
No it doesn't matter where.
Voltage handling capacity is the answer.
A relay shutdown spikes at about 200 volts, thus 1N4001 won't do, 1N4007 are fine.
I use 1N4004 for everything.
specs
Copper - Posts: 120
Posted: January 07, 2015 at 3:50 PM / IP Logged
Thks Howie, appreciate it!
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
