2004 dodge ram, avital 4103
ziggyb222
Silver - Posts: 593
Posted: January 07, 2015 at 3:51 PM / IP Logged
If this 2004 Dodge ram has a black key is there a transponder? Or do all 2004s have them...Have not had a chance to see the truck yet!!!!!
chev104275
Gold - Posts: 1,436
Posted: January 07, 2015 at 5:20 PM / IP Logged
I have yet to see a dodge that year with a black key and a transponder
ziggyb222
Silver - Posts: 593
Posted: January 07, 2015 at 5:29 PM / IP Logged
okay thanks
ziggyb222
Silver - Posts: 593
Posted: January 09, 2015 at 12:34 PM / IP Logged
Installed a 4103 Avital on a Dodge Ram...I am getting a ABS and Brake light on the cluster on in remote start...Powered the two pink wht and pink grn ignition wires and the dark blue accessory at the switch. Tested and had the correct drops in voltage. Starts fine with the remote start, just the two light. Must be missing a wire in the ignition harness????
chev104275
Gold - Posts: 1,436
Posted: January 09, 2015 at 12:54 PM / IP Logged
Definitely missed an ignition or acc Wire. Those trucks have a lot of ing and acc wires
From ready remote
Ignition pink/white + ignition harness
Second Ignition pink/lt. green + ignition harness
Accessory dk. blue and pink / YELLOW (16 AWG) + ignition harness
Second Accessory pink / YELLOW (14 AWG) + ignition harness
From bulldog security
IGNITION 1 PINK/WHITE (+) @ IGNITION SWITCH HARNESS
IGNITION 2 PINK/LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1 DARK BLUE (+) See NOTE *8 @ IGNITION SWITCH HARNESS
NOTE *8 On some Full Size Trucks with Climate Control it may be necessary to connect (3) extra Accessory wires. PINK / YELLOW 16 gauge & PINK / YELLOW 14 gauge and the DARK BLUE Accessory #1 to turn on the A/C Compressor.
Also Not sure on the full-size dodges but I did a Dakota recently and had to power up key sense to keep the factory alarm from going off while the truck was running
ziggyb222
Silver - Posts: 593
Posted: January 09, 2015 at 2:02 PM / IP Logged
Small guage pink / YELLOW needed to be powered.... Works great now..Thanks for the help!!!
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
