accord compustar cranking but not startin
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 2:43 PM / IP Logged
Hi, I am having trouble with my Compustar remote start. I have honestly tried (mostly) everything and I cant get this thing to function properly. Previously it worked great but for the last year its been acting funny. The lock and unlock work on the after market fob as well as the trunk release. Although when I hold down the key button to tell the module to start my car it reaches the car and even cranks the engine but alas the car does not start! The module does start the car if the key is in the ignition and in the on position.
This thing has been a headache for me for a long time now. I have taken the car back to where the remote start was installed (Best Buy (my first mistake)) and they could not figure it out. Please someone help!
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 2:44 PM / IP Logged
2007 Honda Accord 4 Door 4 Cylinder
tedmond
Gold - Posts: 4,610
Posted: January 19, 2015 at 2:54 PM / IP Logged
hold the key (black remote part) next to the key cylinder, try to remote start and see if it runs. if it does start you have an immobilizer issue. a reprogram should do it
Ted
Compustar Expert
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 3:00 PM / IP Logged
I just tried this. It will crank over and over and over a total of three separate times but will not start the car. So that rules out immobilizer?
tedmond
Gold - Posts: 4,610
Posted: January 19, 2015 at 3:12 PM / IP Logged
do you notice a flashing green key in the cluster? If yes its an immobilizer problem.
If no key is flashing, place the key into the ignition and leave it in the on position. (2nd click) activate the remote start and if it starts up there is an ignition problem.
if an ignition problem, look under your dash. Im going to assume this is an order unit so look for a 30 amp fuse on a GREEN wire. this is your ignition output. Change the fuse and you should be good to go
Ted
Compustar Expert
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 3:29 PM / IP Logged
Remote starting with the key in the on position works. So its an ignition problem. Any idea what my next steps would be?
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 3:30 PM / IP Logged
oops just saw the rest of your message :) Ill give it a try!
tedmond
Gold - Posts: 4,610
Posted: January 19, 2015 at 3:37 PM / IP Logged
you will see 3-5 fuses bundled together (if its a good install). You might see 1 red, 1 white, 3 green fuses. one of the green fuses will have popped from excessive current draw.
Ted
Compustar Expert
aftermktheadake
Member - Posts: 7
Posted: January 19, 2015 at 3:47 PM / IP Logged
YOU ARE CORRECT! accord compustar cranking but not startin - Last Post -- posted image. WOOOOOHOOOOOO!!!! I found a popped fuse under there. Ill head over there and replace it after work. Thank you so much! I'm betting this will fix my problem. I cant believe Best Buy Geeksquad tried to figure this out for 2 hours and couldn't and you figure out my problem over the INTERNET! HAH! Ill let ya know if this works for sure after I replace the fuse. accord compustar cranking but not startin - Last Post -- posted image.
aftermktheadake
Member - Posts: 7
Posted: January 30, 2015 at 9:12 AM / IP Logged
This fixed it! Thank you! My car has been nice and toasty when I get into it, even on the coldest days. :^:
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
