2002 trailblazer remote starter
derekh1979
Posted: January 21, 2015 at 10:49 AM / IP Logged
Hello All,
I am going to attempt to install a remote starter/alarm/keyless entry system... I have heard so many different options for the locks and passlock2 bypass... DEI Etc... Whats the easiest single bypass that will do locks passlockII starter the whole thing for a 2002 trailblazer?
Thanks for all your help guys.... and girls...
Thanks,
Derek
chev104275
Gold - Posts: 1,436
Posted: January 21, 2015 at 11:29 AM / IP Logged
I use only idatalink stuff very good combo bypasses. Go to idatalink.com and put your vehicle info then download the guide so you can look it over. Where ever you buy from make sure it's flashed with the firmware you need.
Platinum - Posts: 7,828
Posted: January 21, 2015 at 12:04 PM / IP Logged
I'm with Chev, iDatalink modules can't be beat.  That being said, obtaining the right module, flashed with the correct firmware can be a challenge for the DIY'er.
Here is a link to a Pictorial on your vehicle  :  https://www.the12volt.com/installbay/forum_posts.asp?tid=130514
The Fortin INT-SL+ bypass module used in the Pictorial is a very solid piece and best of all comes pre-loaded with firmware.  Here is a link to the Fortin INT-SL+ info :  http://fortin.ca/en/products/flash-series/int-sl%2B/
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
