Remote Start on 2010 Grand Caravan
ohnam123
Posted: February 05, 2015 at 2:09 PM / IP Logged
Hello all, i am having a problem
I have the following:
2010 grand caravan, dball, python 574 remote starter,CHTHD1 T-Harness.
At Expresskit it says to use Type 1 install for my van.It has 2 options, type1a r7 & type1b r1-r6. The harness package i got says CHTHD1 (rev7) so i assumed i use type1a r7 install, so did.
I installed as follows:
-harness to ignition
-harness to dball 14 pin
-harnessPinkWire ^ remote ign.input/out
-dball12pin:Vio/Gr&Vio/Br^wh/br light sw
-12 pin:yel/bl^vio wire in kick panel
-D2D cable to remote
-+12v from remote to battery
-hood switch connected
-safety switch grounded/not plug to dbll
-black from remote grounded
Tach,shock sensor, siren not connecting
It is flashed, paired, and programmed
Lock/unlock works but not start, start error on 2 way remote and 8 flashes of parking light. I tried safe switch both on and off, but same.
What is wrong and also do you know what the R7 and R1-R6 for harness means? Did i do right with type1a R7 install or do i use the R1-R6? I checked expresskit and found no explanation for the r7and r1-r6.
Do i need to have shock sensor and siren hooked up for it to work? If so the shock sensor has a plug and 1 end of the green wires is loose, does that go to ground?
Sorry so long, but wife keeps on me to get hef starter donem thanks. Tom
Tom
tedmond
Gold - Posts: 4,610
Posted: February 05, 2015 at 3:09 PM / IP Logged
ground your BLACK/ white neutral safety wire, go into programming 3 and change it from manual to automatic.
that should do it
Ted
Compustar Expert
ohnam123
Posted: February 05, 2015 at 3:43 PM / IP Logged
Thank you for the quick reply. Willvdo that when i get home
Tom
ohnam123
Posted: February 06, 2015 at 1:30 AM / IP Logged
well i just got back inside from trying your suggestions. the WHITE/ bl wire is grounded and i switched over to automatic in program 3.
same thing is going on. no start with 8 flashes.
am i doing the right install with the T-Harness?
Type 1a R7. or am i suppose to use Type 1b R1-R6?
and do you know what the R7 and R1-R6 means?
thank you, tom
Tom
tedmond
Gold - Posts: 4,610
Posted: February 06, 2015 at 8:26 AM / IP Logged
8 flashes indicates neutral safety error:
1) Verify you have a solid ground on BLACK/ white (-) 24pin connector
2) Plug in Neutral safe switch and keep it on the ON position. - Personally i always just cut the switch off, and solder the two ends together.
your install type is correct. Temporarily connect the siren, so during programming you know exactly what menu your in. The led flashes are ample if you're experienced with DEI; if not you can easily loose count, and end up programming a wrong setting.
Ted
Compustar Expert
ohnam123
Posted: February 08, 2015 at 12:17 PM / IP Logged
I really appreciate your help and knowledge. After triple checking i took the remote startet out and opened it up since i didv everything correctly with your verification and a solder connection on the pcb was loose and so i resoldered it. Wouldnt you know it all was good. Everything works
Thank you
Tom
tedmond
Gold - Posts: 4,610
Posted: February 08, 2015 at 8:00 PM / IP Logged
That's the first time I've heard of a bad solder joint on a Directed product. Glad you go it working though !
Ted
Compustar Expert
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
