05 Ram Diesel No Lock/Unlock When Remote Started
mav02
Member - Posts: 10
Posted: February 13, 2015 at 9:52 AM / IP Logged
I .am working on a 2005 Dodge Ram diesel when the vehicle is off the keyless works correctly I use the resistors going off the purple green wire connected to a relay set up. My problem is when the vehicle is remote started or started with the key, the Compustar key fob does not lock or unlock the doors the oem one works correctly. the key sense wire is hooked to the wait to start circuit and the option is programmed in the computer. Brain is a CompuStar 7200 and the remote is the g9
tedmond
Gold - Posts: 4,610
Posted: February 13, 2015 at 11:47 PM / IP Logged
the door lock wires are inactive with the ignition on-limitation of the vehicle.
use the arm and disarm wires
PURPLE / Blue (-) Same connector as lock wire. 450ohm arm, 1.8k disarm
Ted
Compustar Expert
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
