Ignition controlled relay with switch override
CHaseHeadrick
Member - Posts: 34
Posted: February 26, 2015 at 5:47 PM / IP Logged Link to Post Post Reply Quote CHaseHeadrick
I have a 2002 wrx that has drl disabled. With the stalk switch in the on position, the headlights are controlled by the ignition circuit. When the ignition is off, they can be controlled via the stalk switch by turning it off, then back on, which turns the headlights on. I also have a 97 4Runner that I'd like to emulate this feature on. Is there a way to do this with no more than 2 or 3 relays? If I can, I'd also like to use the same set up for the radio in the 4Runner. Thanks in advance.
93 4RUnner
Alpine H/U
Alpine Mids/Highs
Alpine Security w/DEI remote
start and window control
Rockford Lows.
CHaseHeadrick
Member - Posts: 34
Posted: February 26, 2015 at 5:52 PM / IP Logged Link to Post Post Reply Quote CHaseHeadrick
I forgot to mention that if the stalk switch is in the off position the headlights are always off. Not sure if that's N2K info or not.
93 4RUnner
Alpine H/U
Alpine Mids/Highs
Rockford Lows.
