2012 GMC Sierra Premium
ziggyb222
Silver - Posts: 593
Posted: March 25, 2015 at 10:49 AM / IP Logged Link to Post Post Reply Quote ziggyb222
Can anyone tell me where to get the door trigger on this 2012 premium Sierra... There is the regular grey/blk at the BCM..that is not it....All my sheets say base model at the bcm pink plug...I do not see a pink plug...white and brown!!!! Thanks
tedmond
Gold - Posts: 4,610
Posted: March 25, 2015 at 1:10 PM / IP Logged Link to Post Post Reply Quote tedmond
on a premium its at the driver door window switch. pin 13
I wouldn't waste time fishing 2 wires for door pins. Instead, white plug at BCM pin 5 Grey (+) is the dome light wire. use this for triggers.
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 25, 2015 at 2:01 PM / IP Logged Link to Post Post Reply Quote ziggyb222
I have always got the grey/blk at the BCM. The dash lights stay on longer than the dome and auto lights. For about 8 mins. But only in the shop. In the day light it is not a issue. On the base models I just pulsed the grey/blk with the rearm wire to fix it...
tedmond
Gold - Posts: 4,610
Posted: March 25, 2015 at 2:47 PM / IP Logged Link to Post Post Reply Quote tedmond
didnt use a convenience module?
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 25, 2015 at 2:53 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Yes...I use all I data...flashed DL-GM10...I am emailing IData tech support...You would think that disarm wire would be in the harness from the door!
tedmond
Gold - Posts: 4,610
Posted: March 25, 2015 at 2:57 PM / IP Logged Link to Post Post Reply Quote tedmond
so you're having an issue with rap shutdown?
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 25, 2015 at 3:06 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Radio shuts down...just the instrument lights stay on....but only if the truck is in the shop...then the instrument lights stay on for 10 mins....out in the daylight...everything shuts off.
tedmond
Gold - Posts: 4,610
Posted: March 25, 2015 at 3:16 PM / IP Logged Link to Post Post Reply Quote tedmond
premium has autolights. regardless of the position you put it in (auto, on or off) the vehicle will resort to auto for safety reasons when it sees ignition.
try pulsing the autolight wire @ the bcm, White plug dark green (-) after the vehicle shuts down. This should shut your cluster lights as well.
The way i see it- the vehicle has a photoelectric sensor somewhere on the dash, or rear view mirror. Under poor lighting conditions, the vehicle keeps the cluster lit for some ambient lighting (in the event the dome light was off) for safety. Outside, its bright so no need to keep it on. Pulsing the autolight wire would simply tell the bcm to shut off all lighting. Just my take on it. Also note, the cluster is all LED based. 10minutes is hardly a significant draw to run that battery flat.
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 25, 2015 at 3:49 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Showed the customer and she was not concerned...I have another Premium coming next week...I will give it a try...Thanks you are the Man!!!!
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
