2012 Nissan Rogue
piorun
Posted: April 14, 2015 at 7:58 PM / IP Logged Link to Post Post Reply Quote piorun
I am installing EVO-ONE and THAR-ONE-NIS2 in 2012 Nissan rogue with intelli key. I hook up all the wires but I can't find wire for Autolight shutdown. Anyone knows where that wire is located?
Platinum - Posts: 7,828
Posted: April 15, 2015 at 4:57 AM / IP Logged Link to Post Post Reply Quote kreg357
Looks like you can use any Door Trigger wire.  Here is the info from ReadyRemote :
Door Trigger       White (-)          @  driver kick or BCM behind glove box, white 15 pin plug, pin 7
If you go to the site & look-up your vehicle, they give you a Photo of the White 15 Pin plug at the BCM with the wires marked :
http://www.readyremote.com/main.asp?make=Nissan&model=Rogue
piorun
Posted: April 15, 2015 at 5:51 AM / IP Logged Link to Post Post Reply Quote piorun
Thank You
