99 Altima Remote Start
eddiestar47
Posted: April 15, 2015 at 12:36 PM / IP Logged Link to Post Post Reply Quote eddiestar47
I purchased Ready Remote Model #23927 and the manual in the packaging ( http://www.readyremote.com/pdf/manuals/23927.pdf ) contradicts the website instructions ( http://www.readyremote.com/main.asp?action=select&yr=2800&product=Remote%20Start&make=Nissan&model=Altima# ). The manual shows vehicle accessory wire connected to ignition 2 on the module. The website shows the accessory wire being isolated using tech tip #1077. I am going to use the website install instructions but, need clarification.
Tech Tip #1077
I need to get a 30 amp relay,
step 1: connect 12V constant to pin 85 and 87
step 2: connect ignition 3 output to pin 86 ??
step 3: cut the accessory wire in half and connect ignition side to pin 87A and dash side to pin 30
step 4: connect accessory output from remote starter to dash side wire
In step 2: I need to ground the relay, it can't be a continuous ground because the blower will stay on when the car is off.
Can I use the ignition 3 wire to connect to pin 86 on the relay?
davep.
Gold - Posts: 649
Posted: April 16, 2015 at 1:35 AM / IP Logged Link to Post Post Reply Quote davep.
Wire the relay like the tech tip suggests, and it will work. In step 2, that is the IGN3 (-) trigger output. When the RS is activated, this output will close the relay, supplying 12V from the relay 87 to the ACCY circuit. In a normal key-on, 87a supplies the ACCY from the key switch.
Follow the tech tip. It will work.
