Can I use a 600V block with 12V and more Amps?
mascip
Member - Posts: 14
Posted: June 02, 2015 at 8:53 AM / IP Logged Link to Post Post Reply Quote mascip
Hi, I'm thinking of using this Screw terminal block barrier double row on my boat.
Its specifications say: 600V and 15A.
Can I instead use it 12V and 60A?
I am guessing that as an approximation, the temperature depends on the power: 600V x 15A = 9000W, which is much higher than 12V x 60A = 720W. Hence, I think that using it with 12V and 60A is safe. Is it?
mascip
Member - Posts: 14
Posted: June 02, 2015 at 11:29 AM / IP Logged Link to Post Post Reply Quote mascip
A friend answered my question:
The resistance in the connections is calculated for 15A current (no matter what the voltage is) so it may overheat.
R I^2 means that the power will be solely dependent on the current, which will probably be mostly determined by other components in the system. So the current rating is the same, whichever voltage I apply.
Tuesday, August 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
