clifford 5906x
yamikenbuilt
Member - Posts: 16
Posted: July 06, 2015 at 5:44 PM / IP Logged Link to Post Post Reply Quote yamikenbuilt
Thanks! Also have a question on the 535T. It says to run a relay so the alarm will be bypassed when closing or opening windows. Which wire on sensor do you cut and use? The impact sensor has 4 wires, one which is cut already and looped.
Posted: July 06, 2015 at 5:52 PM / IP Logged Link to Post Post Reply Quote howie ll
Don't, just leave that at present, remember to wire directly to the motor wires in each door.
Which sensors do you have?
yamikenbuilt
Member - Posts: 16
Posted: July 06, 2015 at 7:12 PM / IP Logged Link to Post Post Reply Quote yamikenbuilt
So I shouldn't wire in a relay and just connect to aux channel and orange ground when armed wire to 535t? I have the impact sensor that comes with alarm and the 508d motion sensor. I want to be able to arm and leave windows down and roll up when I want if possible. I had the 530t hooked up where it would roll up when alarm is armed and aux chanel.to vent or roll down only.
Posted: July 07, 2015 at 2:26 AM / IP Logged Link to Post Post Reply Quote howie ll
Neither of those sensors are active until about 20 seconds after arming so not relevant.
Try activating the windows during remote start, see if that triggers if so you need to cut the power supplies red or grounds black to each sensor.
Thursday, November 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
