2007 F150 Bypass-can't get to program
jhughley
Member - Posts: 12
Posted: July 29, 2015 at 8:28 AM / IP Logged Link to Post Post Reply Quote jhughley
Kreg,
Thanks much for all the help on this project. After some more evaluation, I had a feeling the keys were cloned. I was able to use key2go and got the bypass programmed. Everything works... Would have been an easy project if I would have known about the keys....
again thanks for your help...
Jason
Jason
sjk136
Posted: November 08, 2016 at 1:13 PM / IP Logged Link to Post Post Reply Quote sjk136
Im having similar issues to Jason, with the difference that I believe my Keys are not clones because I get orange flashing lights after I put the second key in and out. Then i press the programming button on the DBALL2 and press the remote start for the 4105 system (which works with key in off position). I've gotten different behavior on the car including having it start with no key, but the lights always end up flashing RED / ORANGE / RED / orange and then the module goes back to solid red after i'm finished.
Im using this guide:
https://directechs.blob.core.windows.net/documents/dball-dball2-ford1_en_ig_vm20150925p.pdf
What wire hookups should I need if I have the 4 pin DTD wires connected? I have the pink wire tied into the main ignition wire. The RAP grounded, the keysense on the BLACK/ pink even though i dont have an alarm. What am i missing?
Working with 2007 F150 Crewcab
But why do I have to pay someone to do it for me?
jhughley
Member - Posts: 12
Posted: November 08, 2016 at 2:15 PM / IP Logged Link to Post Post Reply Quote jhughley
I was getting that same blinking RED / orange light after I entered the second key.
I know the timing on getting the button pressed and everything to program is tricky.
PM with question as this is the same situation that I had.
Jason
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
