Remote start shuts off after 5 seconds
apalacios313
Member - Posts: 16
Posted: October 13, 2015 at 3:50 PM / IP Logged Link to Post Post Reply Quote apalacios313
Hi I just installed an Excalibur 1855 remotes start and the omega TD BLADE, on 2001 Oldsmobile Bravada. The issue Im having is that when I finished installing it everything worked fine, the remote start worked. started the truck 10 times worked fine. but after turning the vehicle back to my friend, he started having issues with the remote start the truck will start than after 5 seconds it goes off, than when he brought the car back to me I remote started it and it worked fine for the first couple of times, than again it would start and go off, than I would try again and it would work fine again.
P.S. thinking it might be the bypass I tried it with the key and it would do the same thing again, it would start than after 5 seconds it would go off. could it be the tach wire that's messing up or what do you think it could be???? thank you..
Aurelio Zamora
mspurewal
Member - Posts: 11
Posted: October 13, 2015 at 6:49 PM / IP Logged Link to Post Post Reply Quote mspurewal
Please look my post on this link if it can help you.
https://www.the12volt.com/installbay/forum_posts.asp?tid=139559&get=last#710799
rs specialist
Copper - Posts: 175
Posted: October 14, 2015 at 7:32 PM / IP Logged Link to Post Post Reply Quote rs specialist
I would guess it is the TACH wire. Where did you connect it to? On a vehicle like this, it will certainly need connected.
