voltage and tach, remote start
mduong25
Member - Posts: 23
Posted: October 15, 2015 at 12:03 PM / IP Logged Link to Post Post Reply Quote mduong25
I wanted to ask if when using voltage sense, there is no physical wire that needs to be hooked up as it is something that is featured in your remote? Where as with tach, there is a physical wire? Any help would be appreciated...thank you.
Twelvoltz
Platinum - Posts: 2,384
Posted: October 15, 2015 at 12:24 PM / IP Logged Link to Post Post Reply Quote Twelvoltz
Most systems will 'read' voltage sensing off of the wires connected to the ignition wiring in the vehicle without requiring any additional connections.
Tachometer connections require a physical connection, and are normally the most reliable method.
