relay control led lights 2way?
davep.
Gold - Posts: 649
Posted: November 15, 2015 at 10:56 AM / IP Logged Link to Post Post Reply Quote davep.
howie ll wrote:
Oh very funny! On a serious note, FUSE the common wire to 87 and 86 BEFORE the switch. This wire is a 12V+ constant.
Good point on the fuse. Use the lt blu/pnk wire at the transmission switch as the power source for the Manual switch. Then the reverse lights, work lights, relay, and all associated wiring is on the same fuse. #28, 10A, in the dashboard fuse center.
Posted: November 15, 2015 at 10:58 AM / IP Logged Link to Post Post Reply Quote howie ll
Is that constant or ignition Dave? Personally I'd have fed the switch from a constant.
davep.
Gold - Posts: 649
Posted: November 15, 2015 at 11:02 AM / IP Logged Link to Post Post Reply Quote davep.
RATS!
Howie caught my mistake, He's right, lt blu/pnk is only hot in RUN. You need a constant.
Posted: November 15, 2015 at 11:04 AM / IP Logged Link to Post Post Reply Quote howie ll
Ha ha!
beachbum561fla
Member - Posts: 42
Posted: November 15, 2015 at 5:31 PM / IP Logged Link to Post Post Reply Quote beachbum561fla
i got it to work and used the original relay diagram that you gave me howie
thanks!!! A+++ works 100% just like i want it to
