Honda Accord 2012 Viper 5706v and Dball instal
egeovanny
Posted: November 10, 2015 at 6:26 AM / IP Logged Link to Post Post Reply Quote egeovanny
Hi
I am working on installing a Viper 5706v and DBALL immobilizer and I face some issues:
Wiring:
Main Harness:
Red 12DC constant input to car white wire
Black ground to car chassis
Remote start:
RED / Black Fused Accessory/started input to car white wire
Red Fused 12V ignition input to car white wire
RED / White fused 12V ignition 2 to car white wire
Green Starter input key side to car yellow *
Violet Started output car side to car yellow *
Pink/White ignition 2 to car orange
Orange accessory output to car red
* yellow wire was split for this connection
DBALL was flashed with the program for the 2012 Honda Accord
issues:
1. The DBALL did not received 12V from the starter thus the light did not came ON . I got 1.5V (not enough) on the red wire from the remote starter to the Dball unit and 5.7V from one of the can communication wire (do not remember color) next to the red. Pressing the button on the remote the starter clicked and the light on the antenna came on but that was it. I was able to start the car using my car key.
2. I read on many post that the 12v problem can be fixed by splitting that wire and connect it to a constant 12 volts thus I tried that. The Dball powered, I was able to program it, the doors locked but the car does not start with the remote, it gives me an error. Also I cannot start my car with the key. It cranks and starts but it shut off immediately
Please help
The world will be better if we all extend the hand to those that need it.
chev104275
Gold - Posts: 1,436
Posted: November 10, 2015 at 7:22 AM / IP Logged Link to Post Post Reply Quote chev104275
How is the dball wired ? D2D or W2W ? What firmware is the dball flashed with ?
egeovanny
Posted: November 10, 2015 at 7:40 AM / IP Logged Link to Post Post Reply Quote egeovanny
I am sorry I missed that part:
DBALL wiring
- HS can High Tan/Black to car B-Can high pink (by ignition cylinder)
- HS can low Tan to car B-Can low blue (by ignition cylinder)
- Immobilizer data ORANGE / black to car immobilizer data Lt Green (by ignition cylinder)
egeovanny
Posted: November 10, 2015 at 7:52 AM / IP Logged Link to Post Post Reply Quote egeovanny
DBALL flashed with Firmware HONDA56 2.19
Posted: November 10, 2015 at 9:44 AM / IP Logged Link to Post Post Reply Quote howie ll
Power up the DB-ALL directly disconnect from 5706 and power and ground directly; see if it does the same thing. If so it's faulty.
egeovanny
Posted: November 10, 2015 at 10:24 AM / IP Logged Link to Post Post Reply Quote egeovanny
I have connected the power of the dball directly to a constant 12V and when I did that I encounter the second issue (see description)
do you want me to do the same with the ground and just leave the CAN connection between the starter and the DBALL?
As an update. I disconnected the Dball, connected an disconnected the started, shout it on and off using the starter switch, i did that in different combination and the car stars and shut off still the issue #2
Posted: November 10, 2015 at 10:28 AM / IP Logged Link to Post Post Reply Quote howie ll
OK, I'm thinking either faulty DB-ALL2 or wrongly wired. I cooked one some years ago on a 2010 Civic, the CAN and data wires are all pastel on UK cars, please double check that you haven't gone to the wrong wire.
egeovanny
Posted: November 10, 2015 at 11:14 AM / IP Logged Link to Post Post Reply Quote egeovanny
Do you know where I can find a reliable wiring diagram for my car?
Also i will like to find out what the voltages on each cable should be to verify my self that I am getting the right output
Posted: November 10, 2015 at 11:26 AM / IP Logged Link to Post Post Reply Quote howie ll
Go to Xpresskit, plug in make, model, year, DB-ALL2 will be listed download the installation guide.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
