One Set of Lights, Two Triggers
AbnMP13
Posted: December 10, 2015 at 5:29 PM / IP Logged Link to Post Post Reply Quote AbnMP13
I put two strips of LED's under my truck for rock crawling/repairs. I want them to illuminate when I open my doors AND from a switch. I bought a 5 pole relay and used the switch as one trigger and puddle light wire as the second. Puddle lights didn't have enough voltage to trigger the relay, added a PAC TR7 to amplify the voltage. Now I need something to go into the LED's positive wire to prevent the voltage from going BACKWARD into the puddle lamp circuit.
Problem is when I turn the lights on VIA the switch the voltage goes into the puddle lamp circuit and turns them on as well.
AbnMP13
2014 Ford Raptor
Platinum - Posts: 13,714
Posted: December 10, 2015 at 7:45 PM / IP Logged Link to Post Post Reply Quote i am an idiot
AbnMP13
Posted: December 10, 2015 at 8:15 PM / IP Logged Link to Post Post Reply Quote AbnMP13
Thanks.
I tried an IN4005, had it leftover from a repair on my Harley, and it got way too hot.
Could you recommend a different size?
AbnMP13
2014 Ford Raptor
AbnMP13
Posted: December 10, 2015 at 9:42 PM / IP Logged Link to Post Post Reply Quote AbnMP13
Also tried Radio Shack 276-1661 MCC * 50V / 6A Rectifier Diodes * 6A05 MR750. But it got real hot too, I know nothing about these things, I browsed the web until I found a similar post and tried what they used.
AbnMP13
2014 Ford Raptor
Posted: December 11, 2015 at 1:40 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Parallel several of the 6 amp devices.
Saturday, June 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
