Omega R&D AL-101 alarm system
solidstrike165
Posted: December 19, 2015 at 11:23 AM / IP Logged Link to Post Post Reply Quote solidstrike165
I recently purchased a car, and in the course of replacing some dash lighting, I discovered the above named alarm box stuffed inside the dash. It was completely disconnected, but all the proper connectors seem to be in place if I wanted to fire it up. The only thing missing are the key fob remotes and installation manual (PDF or print). I have searched the net, including the manufacturer's website, and this forum for what I'm looking for, no joy. If anyone here can help me locate these items, I would be immensely grateful.Omega R&D AL-101 alarm system - Last Post -- posted image.
lectricguy
Copper - Posts: 359
Posted: December 19, 2015 at 2:31 PM / IP Logged Link to Post Post Reply Quote lectricguy
Go on the Omega website (http://caralarm.com) and search for Ultimate.
You can sign up for free access to install and user guides.
This unit could be wired as an add-on, using the factory keyless system, or it could be installed with an option to use Omega remotes. You need to see how it is wired to the vehicle. The install guide should help.
Good luck and I hope this helps.
Lectric Guy
