2007 Tacoma Remote Start
jeremysj
Posted: December 23, 2015 at 12:44 PM / IP Logged Link to Post Post Reply Quote jeremysj
Hello i bought a remote start off Ebay which said detailed instructions came with it (boy was i wrong). I have been researching on this site for two weeks and now im wondering if i bought the wrong thing. from my research seems like no one has installed this, anyways this is what i bought Excalibur model Rs-160-EDP+ with a omega imo5 pkt2 flashed for my truck. I bought this system just for remote start and to be able to use my factory key fobs.
jeremysj
Posted: December 23, 2015 at 12:47 PM / IP Logged Link to Post Post Reply Quote jeremysj
All help would be greatly appreciated
dairyboy3
Copper - Posts: 52
Posted: December 23, 2015 at 3:41 PM / IP Logged Link to Post Post Reply Quote dairyboy3
There is no remote start add on option for the factory fobs for a tacoma. The fobs don't work when the truck is running. Your better off adding a remote start with keyless.
rs specialist
Copper - Posts: 175
Posted: December 28, 2015 at 9:49 AM / IP Logged Link to Post Post Reply Quote rs specialist
^^^ This is not entirely accurate. There are add-on options available to work with your factory system.
http://www.crimestopper.com/products/security/security-systems/remote-start/rs00-g5
This system will work with your factory fobs. That is what it is designed for. If you find the you need more range you can add the 2-way Upgrade kit.
arceecola
Posted: February 14, 2016 at 12:27 AM / IP Logged Link to Post Post Reply Quote arceecola
Hey jeremy, I have the same exact kit for my 07 taco, and just finished making all the wire connections. I'm sitting in my truck looking at all this mess as I type. For the most part I have it working, except that I cannot seem to locate the correct vehicle lock motor wire, which the WHITE/ blue wire from the 14 pin harness on the rs 160 is supposed to connect to. In the testing step, instructions say to touch the WHITE/ blue wire to ground 3 times. I've got that working enough to crank the engine, but the immobilizer doesn't seem to be doing its job of faking the presence of a key transponder near the ignition. When I hold my key next to it, it will start though. So here I am as you were hoping to find a post by someone more knowledgeable and successful in their very similar installation. Have you had any luck with yours?
