Correct module for 11 CR-V/Autopage 730a
labeledbass
Posted: January 09, 2016 at 7:18 PM / IP Logged Link to Post Post Reply Quote labeledbass
Hello, I am installing a Autopage rs-730a into a 2011 Honda CR-V SE, I've searched and found a semi wiring diagram for 07-08 CR-Vs (which should be the same) that will help but I also have iDatalinks ADS-AL CA and a ADS-TB module for remote start. These were given to me so I just wanted to make sure these modules will work for what I'm trying to do here, install a alarm/remote start system in my 11 CR-V.
Hopefully this is in the correct place, if not please direct me. And any other information or location of information on installing would be great, I'm used to older systems but since chipped keys and remote start things have changed, especially when they need to be programed.
Thanks in advance for your help!
live wire
prdjr165
Copper - Posts: 293
Posted: January 10, 2016 at 5:37 AM / IP Logged Link to Post Post Reply Quote prdjr165
the ADS-AL-CA will work for the ignition bypass and alarm feature your looking for.it needs firmware DL-HA2.go to idatalink.com to download the diagram for your ads-al-ca.
honda CRV wiring info:
12volts
      white (50A)
      ignition switch, brown 7 pin plug, pin 3
Starter      yellow      +      ignition switch, brown 7 pin plug, pin 1
Second Starter      N/A
Ignition      blue      +      ignition switch, brown 7 pin plug, pin 6
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange      +      ignition switch, brown 7 pin plug, pin 4
Second Accessory      red      +      ignition switch, brown 7 pin plug, pin 5
Keysense      gray      -      ignition key switch, green 6 pin plug, pin 1
Power Lock      blue      -      driver kick, door harness
Power Unlock      gray      -      driver kick, door harness
Lock Motor      pink      5 wire      dash fuse box, green 42 pin plug (E), pin 21
Unlock Motor      gray      5 wire      driver kick, door harness
Parking Lights+      red      +      above driver kick, blue 18 pin plug, pin 1
Parking Lights-      blue      -      headlight switch, WHITE/ black 12 pin plug, pin 11
Hazards      purple      +      hazard switch, green 6 pin plug, pin 5
Turn Signal(L)      orange      +      dash fuse box, green 42 pin plug (E), pin 40
Turn Signal(R)      brown      +      dash fuse box, green 42 pin plug (E), pin 39
Reverse Light      brown      +      dash fuse box, green 42 pin plug (E), pin 15
Door Trigger      green      -      dash fuse box, green 42 pin plug (E), pin 37
Dome Supervision      purple      -      right of dash fuse box, white 20 pin plug, pin 19
Trunk/Hatch Pin      pink      -      dash fuse box, green 42 pin plug (E), pin 36
Hood Pin      lt. blue      -      dash fuse box, blue 21 pin plug (G), pin 13
Trunk/Hatch Release      white (rear handle switch)      -      dash fuse box, green 42 pin plug (E), pin 13
Power Sliding Door      N/A
Factory Alarm Arm      pink (driver door key cylinder)      -      driver kick, door harness
Factory Alarm Disarm      brown (driver door key cylinder)      -      driver kick, door harness
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT yellow/black      ac      any fuel injector
Wait to start      N/A
Brake Wire      lt. green      +      dash fuse box, green 42 pin plug (E), pin 34
Parking Brake      purple      -      below dash fuse box, white 24 pin plug, pin 10
Horn Trigger      orange      -      horn switch, white 20 pin plug, pin 1
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
MAKE : HONDA | MODEL : CRV | YEAR : 2011
labeledbass
Posted: January 10, 2016 at 10:32 AM / IP Logged Link to Post Post Reply Quote labeledbass
Thank you so much! I didn't get so far into ithe but I'm assuming I have to flash the firmware using some type of USB interface for my pc?
live wire
labeledbass
Posted: January 15, 2016 at 10:32 PM / IP Logged Link to Post Post Reply Quote labeledbass
Hello again, I've researched idatalink and I think my module is already flashed, I can't call and ask, it's too late.
On the side of the box it states this -
ADS-AL CA
ADS-AL (DL)-CH4 2.5
AL (64) 1.24
Now I assume some of those numbers reference the rom, when I look my car up, 2011 honda cr-v, I don't see any of these numbers, similar but not the same.
If someone could shed some light that would be great, I'm not positive the car was specified when she bought the mod so I don't really understand how it could be programmed already. I am aware of it doesn't have anything on it I will have to get it flashed or buy the pc connext to do it myself.
Thanks in advance! Really want to get this in
live wire
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
