where can i get connectors
robHI
Member - Posts: 35
Posted: May 27, 2003 at 5:26 PM / IP Logged
where can i get some 3M t tap connectors??? I just need around 15 connectors and i do not want to order a 100.
bdl666
Silver - Posts: 330
Posted: May 27, 2003 at 6:14 PM / IP Logged
  Try this http://www.partsexpress.com
  Or check if a local shop will sell you some.
copcarguy
Copper - Posts: 122
Posted: May 28, 2003 at 4:50 PM / IP Logged
Not to be a nervous nelly but watch out for T-taps. They are notoriously unreliable and often the "weak link" that bite you in the butt on an install or even customer comebacks.
Better option would be to cut the wire you want to tap into, twist one end of the cut wire with the "tap" wire and put them into a seamless crimp connector, double strip the other end of the cut wire, fold it over and put it in the other end of the connector and crimp. This gives a positive contact everytime.where can i get connectors - Last Post -- posted image.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
