Compustar CM-7200 and 2010 F150
pondskipper
Posted: January 16, 2016 at 5:24 PM / IP Logged Link to Post Post Reply Quote pondskipper
Can anyone tell me if the CM-7200 has a programmable disarm input? I have the CM-7200 with the remote start and alarm hooked up with a Drone system also.
I am wanting to use the keypad on the outside of the door to disarm the alarm when the code is entered correctly. Right now it sets off the alarm when opening the door.
Would PIN12 BROWN / White (PIC3) Key Sense INPUT (-) work to shut off the Compustar alarm? I realize I could do this sending a pulse from the door lock switch (-) to an alarm trigger input. If the Compustar has one.
I'm not worried about the fact that someone could shut the alarm off once in the vehicle, because as soon as the alarm has been triggered - the Drone has already sent the signal to my phone and I will get the message even if the alarm is disarmed from inside.
Also - what wire would I connect the PIN 11 Orange to to make the domelights light up when the door locks are unlocked/ alarm disarmed?
Thanks.
