2011 mkz remote start issues
reeves1017
Posted: January 24, 2016 at 12:49 PM / IP Logged Link to Post Post Reply Quote reeves1017
Hi, I'm looking for some help on my 2011 Lincoln MKZ remote start install. This is my first aftermarket remote start install. I installed a dei 4003 with 556u bypass. I wired it all up and programed it to 3 pulses with the factory keyless entry. I tried to remote start it and learn the virtual tach but it won't even crank.   Anyone have any experience with these?
chev104275
Gold - Posts: 1,436
Posted: January 24, 2016 at 3:07 PM / IP Logged Link to Post Post Reply Quote chev104275
What happens when you try and start the car ? What does the theft light do ?
reeves1017
Posted: January 24, 2016 at 4:00 PM / IP Logged Link to Post Post Reply Quote reeves1017
Nothing it doesn't even turn on. Nothing powers up or anything. I'm pretty sure I have it right I have to lock wire and set to -
Here is. My wiring
Main harness 9 pin
1. Light green black factory alarm disarm -n/a
2 GREEN / WHITE factory alarm arm-n/a
3 yellow ignition out to host- n/a
4 white blue activation input- gy-ye lock wire
5 orange anti grid output -n/a
6 brown horn-n/a
7 RED / white-trunk release- n/a
8 black-chassis ground
9 white light flash output-n/a
Heavy guage connector
1 red 12v - blue/red power at ignition
2 pink/ white accessory circuit- violet green on switch
3 red 12v- blue/red power at ignition
4 orange output to accessory circuit-n/a
5 purple output to starter circuit- blue/ white on ignition switch
6 pink output to primary ignition circuit-white orange at ignition switch
Satillite harness 4 pin
1 blue status output- to 556u bypass
2 orange acessory output- n/a
3 purple starter output- n-a
4 pink ignition output- n/a
Remote starter harness
1 neutral safety switch-ground
2 violet/white tach n/a
3 brown brake shutdown-vt/wh at brake switch
4 gray hood pin switch-ground
5 blue/white 2nd status- n/a
Door lock harness
1 blue.unlock-vt gy
2 not used
3 green lock- gy-bn
Platinum - Posts: 7,827
Posted: January 24, 2016 at 4:50 PM / IP Logged Link to Post Post Reply Quote kreg357
I see a few errors.
Heavy gauge connector
2 pink/ white accessory circuit- violet green on switch   **
4 orange output to accessory circuit-n/a **
**  If you do it this way, you must program the 4003 to Flex Relay = ACC2.  Much easier to leave the Pink/White not
connected and run the Orange wire to the cars Violet/Green ACC1 wire.
4 gray hood pin switch-ground      ***
***  Not to ground.  Connect to Kit supplied hood pin switch.  You can leave it not connected during testing.
Main harness 9 pin
4 white blue activation input- gy-ye lock wire    ****
6 brown horn-n/a
****  You can not used the (-) Door Lock wire for this purpose.  You will need to get a relay and use the (+) Driver Door Lock
Motor wire.  First as a test, disconnect this wire from the car and briefly touch it to chassis ground briefly 3 times in 5 seconds.
The car should start if everything else is OK.
Posted: January 24, 2016 at 5:04 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is the info on the Driver Lock Motor wire :
Lock Motor  Gray/Brown  5 wire     @ driver kick or SJB, black 32 pin plug (D), pin 6
You will need a 30/40 Amp SPDT relay.  Here is the wiring :
Relay Pins 85 and 87 to Chassis Ground
Relay Pin 86 to Lock Motor wire  Gray/Brown   @ driver kick or SJB, black 32 pin plug (D), pin 6
Relay Pin 30 to 4003 Pin 4 WHITE/ blue (-) activation input
Don't think these wire are necessary with an add-on 4003 :
Door lock harness
1 blue.unlock-vt gy
2 not used
3 green lock- gy-bn
You could set the 4003 Parking Light jumper to (+) and connect the White Parking Light Output wire to this wire :
Parking Lights (+)     PURPLE / white (+)     @ driver kick or SJB, gray 13 pin plug (E), pin 6
reeves1017
Posted: January 24, 2016 at 5:57 PM / IP Logged Link to Post Post Reply Quote reeves1017
Awesome, thanks so much for the help I'll try it tonight and see if it works
reeves1017
Posted: January 26, 2016 at 6:23 PM / IP Logged Link to Post Post Reply Quote reeves1017
Hey thanks for your help kreg357 the vehicle starts and autostart works awesome
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
