4103 09 nissan titan
jdmdohcpower
Posted: January 29, 2016 at 4:56 PM / IP Logged Link to Post Post Reply Quote jdmdohcpower
Totally a newbie here but I am handy just need some guidance. So I have an 09 Nissan titan that has a 4103 with 4 button remote that locks/unlocks and starts. However it does not talk to the factory alarm. For example if I lock the car with the factory remote and use the viper remote to unlock, the alarm goes off when the door is opened. I know I need to run the GREEN/ black and GREEN / WHITE from the RS unit to the factory arm and disarm wires. Can anyone help me with this. I think they are in the door but what wires and how do I test to make sure its right?
mscguy
Copper - Posts: 212
Posted: January 29, 2016 at 6:02 PM / IP Logged Link to Post Post Reply Quote mscguy
http://www.readyremote.com/main.asp?action=select&yr=24904&product=Remote%20Start&make=Nissan&model=Titan#
Factory Alarm Arm      blue (driver door key lock)      -      power window main switch, white 16 pin plug, pin 6 or 4
Factory Alarm Disarm      red (driver door key unlock)      double -      power window main switch, white 16 pin plug, pin 7 or 6
Unlock wire will show voltage at rest, and drop to 0 volts when driver key is turned to unlock.
Lock wire is the same but drops to 0 at lock.
Program disarm wire to double pulse.
Platinum - Posts: 7,828
Posted: January 29, 2016 at 6:04 PM / IP Logged Link to Post Post Reply Quote kreg357
MSCGUY beat me but here it is anyway...   4103 09 nissan titan - Last Post -- posted image.
Probably the easiest way to do it is by running the 4103 Lock and Unlock wires into these empty pins of the White 40
BCM connector instead of where they are now connected.
Lock/Arm M18 White 40 pin 08 Empty (-)        @ BCM right of steering column
Unlock/Disarm     M18 White 40 pin 07 Empty (-)        @ BCM right of steering column
Typically a 1N4001 diode is inserted into the empty pin holes ( band towards the 4104 ) and secured with tie wraps to
adjacent wires.
You can also do it by running the 4103's lock and unlock wires into the driver door and going to the power window master
switch.
Factory Alarm Arm blue (driver door key lock) (-)       @ power window main switch, white 16 pin plug, pin 6 or 4
Factory Alarm Disarm         red (driver door key unlock)  double (-)    @ power window main switch, white 16 pin plug, pin 7 or 6
Going with these wires, you would have to program the 4103 to a double unlock pulse.  Here is a photo of the connector
with the Red and Blue wires highlighted :
jdmdohcpower
Posted: January 29, 2016 at 9:42 PM / IP Logged Link to Post Post Reply Quote jdmdohcpower
So if I understand correctly I do not need to use the alarm arm and disarm on the RS unit. I use the lock/unlock wires and run them to the red and blue wires above in the power window bundle? How about programing double unlock pulse, how do I go about that?
jdmdohcpower
Posted: January 29, 2016 at 9:44 PM / IP Logged Link to Post Post Reply Quote jdmdohcpower
mscguy
Copper - Posts: 212
Posted: January 29, 2016 at 11:29 PM / IP Logged Link to Post Post Reply Quote mscguy
Did your unit come with an install manual?
If not, its downloadable on here in the downloads section.
Programming Menu 1, Feature 5, Option 2.
Involves some button pressing and horn honks, so if you're doing this outside and changing a bunch of options, be prepared for people to watch you :D
