2015 Toyota Yaris radio wiring diagram
tagree6w
Member - Posts: 6
Posted: February 01, 2016 at 10:01 AM / IP Logged Link to Post Post Reply Quote tagree6w
Hello! I'm currently trying to install an amp into a 2015 toyota yaris. I'm pretty sure it's an SE. I can't seem to find a wiring diagram on your site for the radio.
Any help would be welcome, thank you.
Platinum - Posts: 13,725
Posted: February 01, 2016 at 11:58 AM / IP Logged Link to Post Post Reply Quote i am an idiot
http://metraonline.com/part/70-1761
Does this look like the correct wiring harness if you were going to change the radio out? If so, you can see where the Green and GREEN/ Black wires are. The Violet channel is laid out just as the green channel.
tagree6w
Member - Posts: 6
Posted: February 01, 2016 at 3:23 PM / IP Logged Link to Post Post Reply Quote tagree6w
I have not pulled the radio, and will not until wednesday. However, i am not replacing the radio. The only reason i needed to know the wiring for it is so i know what color the speaker wires are to be able to install the rockford pbr300x4.
I will check to see if this helps me then haha. Thanks so much
Posted: February 01, 2016 at 5:39 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I know you are not changing the radio. If that looks like the right harness if you were changing it out, there is enough information in that picture to give you what you need.
tagree6w
Member - Posts: 6
Posted: February 01, 2016 at 7:48 PM / IP Logged Link to Post Post Reply Quote tagree6w
Yeap, thanks again!
I'll let you know how it goes.
tagree6w
Member - Posts: 6
Posted: February 18, 2016 at 12:59 PM / IP Logged Link to Post Post Reply Quote tagree6w
Sorry, we had some crappy weather here and i have no shop to work in. The amp install went great and the harness was exactly as planned. Thank you very much and sorry for the delay.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
