99 suburban 5706 remote start
harebare
Member - Posts: 18
Posted: March 23, 2016 at 11:41 PM / IP Logged Link to Post Post Reply Quote harebare
Installing a 5706 with remote start using pljx to bypass passlock2. Starts up using key but not remote starting.
Platinum - Posts: 7,827
Posted: March 24, 2016 at 6:09 AM / IP Logged Link to Post Post Reply Quote kreg357
The PLJX is not my favorite bypass module for a couple of reasons but...
Your truck has the Passlock2 immobilizer system, so you would follow the PASSLOCK 2 & VATS CONNECTION diagram
in the install guide.  Unfortunately that diagram shows connections for both systems, so you must exclude those connections
that are used with the VATS system.
A couple of important things to mention :
I don't believe the Keysense wire is needed for your install.
Do not connect the PLJX's Brown wire to the R/S's GWR ( 5706 Dark Blue (-) 200mA Status Output ) wire until programming is
successfully completed.
The PLJX must get it's "Chassis Ground" connection from the Passlock2 Ground Reference wire.
Verify that your have the correct Yellow Passlock2 Resistance wire with a DMM.
Make sure the PLJX jumper is in the B position.
I would recommend that all the Passlock2 connections be properly soldered.
Of course, all the above assumes that the R/S is connected properly to the truck's ignition wires and programmed correctly.
harebare
Member - Posts: 18
Posted: March 24, 2016 at 11:06 AM / IP Logged Link to Post Post Reply Quote harebare
Thanks for the reply kreg357. I'm pretty sure that I have all the connections. I did a search but all I found was a pictorial for one you did with the Avital on a Silverado.
harebare
Member - Posts: 18
Posted: March 25, 2016 at 4:47 PM / IP Logged Link to Post Post Reply Quote harebare
Went back and looked over my wiring connections. Closer look revealed that I did not have all of my wires connected where they should have been.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
